Hello!
A few months back got my 1er and it had a Parrot ck3000 hands free kit installed in the glovebox but there was no microphone in the car so I have brought a microphone for it to plug in and fit it!
I have found the parrot box that has been mounted underneath a plastic panel under the glovebox in the passenger footwell. Now it looks like the 3.5mm microphone Jack is already in the box which is strange but i cannot get the box out has there is a couple of connector blocks in the way. See pictured below (as best I could);
My question is can I remove the blue connector block so I can get the blue parrot box out. If so should I disconnect the battery first (will I lose any coding disconnecting the battery for 20 minutes)
Any help would be appreciated thank you!
