Hi my 116d 2017 has started making the bad noise as per the video When started from cold. It sounds also like it’s dropping off a cylinder. I would be grateful if any one has any ideas
thanks
Steve
I’ve got a guy with a code reader coming round to see if there’s any codes.
as it sounds like it drops partially on1 cylinder when it rattles I have a feeling it’s an injector. Will let you know what I find
It’s actually the belt tensioner making the noise. It is moving quite a lot? I have removed the belt but all the pulleys seam to turn smoothly.
The tensioner spring was strong and needed a good lever to remove the belt
Any ideas please?
The alternator turns smoothly. The a/c pulley spins very freely. I am unsure if that is right but there is no notchyness
i don’t know about the belt. I will have to try and find a photo. This is now it was
Didnt sound like a big end bearing, or injector because wasn’t in a fixed interval. Looks like a pully or tensioner, a mechanic would be able to find the cause.
