BMWhat APP
1.2K views 0 replies 1 participant last post by  Allanv
So I thought I would try the app and see what if anything was lurking around and sent the file off to the very helpful guy and here is the results.
Which mean bugger all to me so anyone be so kind as to shed some light please?
Fault Report - BMWhat - Version: 12.03
ID1: a4fc8d24-8444-4b1a-aa7b-95b9ff4c7c7b-85cID2: dacfe325-f817-44bb-b58c-25238cac8407-e2c
INFO: USB-MODE
Base: E87
Faults: 8
ECUs: 17
Model: 130 i N 52 B 30 A
Battery: no battery info
Normal communication
Normal connection
Date: 2014-06-21 12:57:38
USB Device
Version: 16
Device: >rockchip< >rk30sdk< >3305-1030<
Motor Control:
Engine / Motor
ECU OK, no Fault Code
ABS / DSC / Brake:
Dynamische Stabilitaets Kontrolle / DSC
Fehler: Brake pad wear VA / DSC ECU intern / ECU internally: Runtime MICRO2 / Internal Error / Internal ECU operating error DSC / VASP
Code: 5DE0
Fehler: Steering angle sensor / Steering angle sensor signal / Right rear wheel speed sensor / Lateral acceleration sensor offset errors / Right rear wheel speed sensors / Wheel-HR
Code: 5E40
Airbag:
Airbag
Transmission Control:
Transmission / Getriebe GS 19
ECU not present/no response from ECU
Instrument cluster:
Instrument cluster / Kombiinstrument
Central info display / Zentrales Display
Heating / AC:
Air conditioning / Klimaanlage
Immobilizer System:
CAS
Fehler: Communication errors
Code: A114
Fehler: STOP error
Code: A116
Park distance control:
Park Distance Control / PDC
Sunroof / Roof:
Sunroof / Schiebedach
Roof / Dach
Fehler: Standardization / SHD failure
Code: A092
Fehler: unknown failure / unkown failure
Code: A670
Audio/Navi/Communication:
Phone / Telefon
Hifi Amplifier / Verstaerker
Tuner Antenna / Antenne
Hybrid Radio USA
Digital Satellite-Tuner USA
Navigation
CD-Changer / Wechsler
Audio-System
Video
Seats:
Seats / Sitze
Seats / Sitze
Systems:
Junction Box Passenger / Beifahrer
Fuel pump / Kraftstoffpumpe
Tire pressure control / Reifendruck Kontrolle
Passive Go System
Car Communication Computer CCC
Fehler: unknown failure / unknown fault
Code: E18C
Fehler: Message failure / unknown failure / unknown fault
Code: E18D
Car Communication
Anti-theft alarm system:
Interior protection / Innenraumschutz
Theft alarm / Diebstahl Warnanlage
Body:
Trailer / Anhaenger
Fussraummodul /FRM
Thank you.
