Simple?? Hell no, the manual makes it sound simple.. "simply" push down the clip.. whatever... man, that was a nightmare seriously. Taking it off is relatively simple, afterall you're just loosening everything and you can feel that things will come off, but the clip "must" clear those wires or else you can't pull the clip further down, this invovlves some fine finger manouever techniques... there is no need to disconnect the wires.
OK then you take the bulb/holder out and pull the bulb off. Not the highest quality or the best design i've seen, you really can't avoid touching the bulb itself and the holder feels cheap, but anyway you replace the bulb, then you realise you need to put everything back - put the bulb back into the hole and clip it back, but which way round??? there is only one coordination that would allow the thing to secure, so you start trying, sounds simple again but you won't know if you were right until you put the bulb/holder back into the hole and pull the metal clip back up, and try to secure it as it was before, but this again invovles "the clip clearing the wires" because they are ALWAYS in the way, then chances are you will find out you were wrong, and repeat the whole process again, just to find out you were actually right... :band: I used to think E46s bulb replacement was difficult enough but this makes the E46 job a piece of cake.
AND, that headlight cover..!!! not the easiest fitment, and I dropped one of those metal pieces (that tightens the holder) down because i was trying so hard to fit the cover back.
I should add that maybe the newer or facelifted models is improved? i don't know, mine's just a 2004.
By the way, i still can't figure how to take off the side repeater bulb... i tried to just pull, but it doesn't come off, and it certainly doesn't look like a twist and pull because there's a clip thing that holds it in place. WOuld be nice if someone can give me tips on that
