DIY: Cold air intake upgrade F20/21 M135
Tommi
Post by Tommi »
Sorry my bad English, but I try to do my first DIY to babybmw websites.
If you use INJEN, Burger etc. intakes, this might bring some help to get more cold air to filter.
First remove right side gill from front bumper.
instructions
https://www.newtis.info/tisv2/a/en/f20- ... r/GuBbc6QE
Use tools like this.
Then remove underbody panel from right side (there is located air temperature sensor) by undo 8 mm screws.
Ater removing the grill you will see this
front
and behind
After this I just saw a hole to that Black plastic like this
Then I use thin aluminium plate and made this
And here it in inside of the bumper
And then just the grill back
Hopefully now there will be moore cold air here
Easy job to do.
Return to “How To's”
