A quick timeline of ownership with this car
May 2019 - Bought a 2006 BMW E87 130i manual as a second 'fun car'
June 2019 - Bought a 2008 BMW E82 135i manual write off as a track car
Aug 2019 - New Enkei ES Tarmac 17x9 inch +40 wheels with Kumho V720 tyres, H&R springs, M3 lower control arms, 135i front brakes
Oct 2019 - Plans changed with the 135i so decided to swap the N54 driveline into the 130i (more on this below)
Jan 2020 - LCI dash update and HIZPO stereo (works incredibly well!)
Mar 2020 - I broke it
Current spec - July 2020
Driveline
135i N54 engine
135i 6 speed manual
E82 3.46 open diff
JB4
Catless downpipes
VRSF intakes
VRSF intercooler
Suspension/Brakes
135i 6 piston front brake callipers/discs
Braided brake lines
H&R springs on factory M-sport shocks
90mm stud and nut conversion
Wheels/Tyres
Kumho V720 245/40 tyres
Interior
HIZPO stereo
M-sport interior trims
Conversion
In about October 2019 I decided I wanted to attempt the N54 swap. I know a few E87s are floating around with N54s but couldn't really find much. It was actually reasonably straight forward. Everything bolted into the E87 body. Keep in mind I had a complete E82 to work with. I ended up using the E82 engine mounts, radiator, AC lines, PS lines, gearbox mounts, gearbox linkage, driveshafts, 3.46 ratio diff, instrument cluster and exhaust. The only thing that was modified was the E82 exhaust rear section as it was too long. The pain in the arse part of the swap was the wiring. Mainly because no matter how hard I looked I never found a completely accurate wiring diagram for either car, and I spent hours looking. Once done it was an awesome car to drive and very unsuspecting! Unfortunately, when I did this conversion I cheaped out on maintenance, something which came back to bite me.
Current state/plans
In about March 2020 I had a major coolant leak. I found the rubber part of the transfer pipe leaking. I attempted to replace it then realised you have to remove the downpipes to get to it thus meaning I had to remove the subframe. I noticed some of the other coolant hoses looking pretty tied and the valve cover leaking. I ended up ordering most of the coolant hoses, gaskets and all the other maintenance pieces required. I figured when they arrived, I would remove the subframe and do it all at once. Then I got thinking, if I am removing the subframe, why not fix the turbo waste gate rattle. That idea quickly went to, why not just replace the turbos? A couple of days later I ordered a pair of Dynamic Autowerx TD04 turbos, larger VRSF intakes and a full gasket kit.
As it currently sits, I am still waiting on the turbos to show up. Whilst I have been waiting, I have been gathering all kinds of parts. I got a hold of some used Eibach coil overs and Recaro seat. There is going to be a fair bit of work to make coil overs fit with 9-inch front wheels. I also bought a M factory plate type LSD centre to go into a E82 automatic 3.73 ratio diff which I will install later on.
Driveline
135i N54 engine
135i 6 speed manual
E82 3.46 open diff
JB4
Catless downpipes
VRSF intakes
VRSF intercooler
Suspension/Brakes
Braided brake lines
Wheels/Tyres
Interior
HIZPO stereo
Conversion
Current state/plans
