OEM Xenon retrofit (now complete)
Moderators: Lambster, marco_polo, Rich196, babybmwadmin, Producethis
bjt
Re: OEM Xenon retrofit (now complete)
Post by bjt » Mon Jun 17, 2019 2:37 pm
Good progress! I used the smallest flathead from a cheap set of jeweller's screwdrivers to remove the pins.
Post by Twenny » Mon Jun 17, 2019 3:22 pm
bjt wrote:Good progress! I used the smallest flathead from a cheap set of jeweller's screwdrivers to remove the pins.
Yeah thanks Ben. Think I’m ready to fit the headlights once pin remover arrives.
My hope now is that my FRM3 basic doesn’t need replacing with FRM3 MAX. That’s £150 I don’t have!!
If it doesn’t I’ll be as happy as a pig in poo!!!
P-Torqued 266bhp-BMWP exhaust+Strut+intake+skirts+grilles---Rieger diffuser-Darklines-retrofit cruise control-M135i front brakes-VMR v710-Eibach ARB
Post by Twenny » Sat Jun 29, 2019 10:09 pm
Headlight pins changed. FRM pins changed. Xenons are in.
Still need to code them to the car and see if FRM XL is needed.
At the moment nothing is working (halos, shutters, high beam, low beam) and both the low beams are flashing constantly when switched on.
But they look good fitted.
DC11
Post by DC11 » Sun Jun 30, 2019 12:41 pm
It’s crazy just how much of a difference xenons make on e8* models.
Lookin’ good. 8)
Edit: Do you still have one orange bulb in?
130i LE | BMWP Exhaust | BMWP Intake | Bilstein B4S/Eibach Pro | Whiteline Inserts | M3 LCAs | M3 Transmission Mounts | BMWP SSK - Here
130i LCI | BMWP Brakes, Exhaust, Intake and Interior | Eibach Pro Springs | Whiteline Inserts | M3 LCAs - Gone
Post by Twenny » Sun Jun 30, 2019 3:50 pm
DC11 wrote:It’s crazy just how much of a difference xenons make on e8* models.
Lookin’ good. 8)
I had depo angel eyes with HID kit before fitting these and agreed they make a huge difference to how the car looks.
And Lol no mate it’s the reflection off a yellow skip/bin.
DC11
Post by DC11 » Sun Jun 30, 2019 8:31 pm
:lol:
Post by Twenny » Tue Jul 09, 2019 7:03 pm
A little update.
Coded $522 and the low beams now don’t flash and the shutters work......sort of.
With the headlights turned off I can flash and the low beams work as they should. BUT, with low beams switched on the flasher doesn’t work.
I now have an FRM 3 MAX that will be fitted and coded this weekend so I’m hoping it will all fall into place.
Question? What does this light now do? From looking at a couple of mates Xenons pwhat I can work out it does nothing.
Post by marco_polo » Tue Jul 09, 2019 7:06 pm
It does the square-root of fuckall.
AndyBish135i
Post by AndyBish135i » Tue Jul 09, 2019 8:23 pm
Should suit Con very well then... :lol: :lol: :lol:
Post by Twenny » Tue Jul 09, 2019 8:36 pm
marco_polo wrote:It does the square-root of fuckall.
Phew thank fook for that!!!! Thanks MP
Post by Twenny » Tue Jul 09, 2019 8:37 pm
Harsh Bish harsh. True enough but it still hurts haha
Post by Twenny » Fri Jul 19, 2019 12:32 pm
Success!!!!!
Massive thank you to the OP Ben (bjt) without him this wouldn’t of been possible.
I do have a few minor additions to make to the install that might help newbies like myself.
Firstly - to re pin the headlight plugs there are some plastic retaining clips on either side of the plug that need removing before unplugging the pins (see below)
These can be unclipped and opened out to reach the pins underneath.
Also @bjt - you need to amend one of your wiring colours Image
The second red ring should read White/Green not White/Blue.
Had to buy an FRM Max as the halos and shutters wouldn’t work. But once all coded everything works perfect.
Again a massive thank you to Ben. You’re a legend.
J0sephx
Post by J0sephx » Fri Jul 19, 2019 6:59 pm
Top work fella!
Before:
2006 E87 130i M Sport - RIP
After:
AndyBish135i
Post by AndyBish135i » Fri Jul 19, 2019 7:23 pm
Result...! :fest:
Good job that man :D
DinoM2
Post by DinoM2 » Fri Jul 19, 2019 7:52 pm
Good work
Am tempted to do this to my e87 123d
