Bulb upgrades advice
kaney1980
Post by kaney1980 »
Hi all,
Looking for advice on the correct spec of Silvertec bulb to replace all the indicator and side repeater bulbs on my late 2008 LCI 123d M-Sport as well as advice on the best value upgrade front lights. Hard to pin down the info with so much on the forum!
Front indicators -
Rear indicators -
Side repeaters -
Front sidelights -
Front headlamps -
Thanks,
Gary
Berg3.0
Re: Bulb upgrades advice
Post by Berg3.0 »
This should give you an answer on witch bulb type to use and where.
https://www.philips.co.uk/c-m-au/car-li ... 0Indicator
Post by Octavius »
Indicators. Osram Diadem PY21W
Side repeaters. Osram Diadem W5W
Sides. Osram Cool Blue Intense W5W
Headlight. Osram Nightbreaker H7
Many others are available but I used these on all three of my E series and found hem very good.
kaney1980
Post by kaney1980 »
Berg3.0 wrote:
Sat Jun 08, 2019 10:22 pm
Thank you!
kaney1980
Post by kaney1980 »
Octavius wrote:
Sat Jun 08, 2019 10:24 pm
And thank you!
Post by Octavius »
kaney1980 wrote:
Fri Jun 14, 2019 7:56 am
And thank you!
No problem.
Nottnowcato
Post by Nottnowcato »
Octavius wrote:
Fri Jun 14, 2019 11:01 am
And thank you!
No problem.
Out of curiosity (and because I like the sound of some nice icy blue sidelights) are all these a straight swap, or is there coding required?
2011 E81 116i with the stingiest set of optional extras you've ever seen
Post by Octavius »
Like for like fitting and no coding required.
Nottnowcato
Muoy bueno!
