F21 interior change over issue
E and F series coding & Diagnostics, performed on site and remotely.
Cable sales -- Loan cables – Cruise control retrofit options for all 1 & 2 series cars.
Coding options for all BMW cars and competitive prices.
Moderators: Rich196, marco_polo, Producethis, Lambster, babybmwadmin, BRDiagnostics
Wibbles
Re: F21 interior change over issue
Post by Wibbles » Wed Nov 16, 2016 9:06 pm
iAde46 wrote:Hi,
Anyone local to the northwest that can help with a diagnostic, since the change over I've got a passenger restraint error.
Have you got a cable & software?
Did you unplug a seat without disconnecting the battery?
BRD on Facebook
iAde46
Post by iAde46 » Wed Nov 16, 2016 10:00 pm
I called in at friends garage to see if it was because I removed the battery, the codes they got where 93093a, 930982, 9309ca, 930b8f.
iAde46
Post by iAde46 » Wed Nov 16, 2016 10:01 pm
Wibbles wrote:
iAde46 wrote:Hi,
Yes I have a cable and some software from a previous coding. I did unplug the battery beforehand. I've since noticed an extra box under the seat which I didn't have on the other seat.
iAde46
Post by iAde46 » Wed Nov 16, 2016 10:03 pm
iAde46 wrote:
Wibbles wrote:
iAde46 wrote:Hi,
iAde46
Post by iAde46 » Thu Nov 17, 2016 4:25 pm
Can anyone help?
Wibbles
Re: RE: Re: F21 interior change over issue
Post by Wibbles » Thu Nov 17, 2016 4:32 pm
iAde46 wrote:Can anyone help?
Try posting in the F20 section as this is my Sponsors section.
BRD on Facebook
iAde46
Post by iAde46 » Tue Nov 22, 2016 5:47 pm
Still struggling what to do next here, I've since checked the seat plugs and found these are different (more pins) also an extra box with more wires than on the original harness.
Anyone any ideas before I just give up and put the old interior back in?
BRDiagnostics
Post by BRDiagnostics » Tue Nov 22, 2016 9:37 pm
iAde46 wrote:Still struggling what to do next here, I've since checked the seat plugs and found these are different (more pins) also an extra box with more wires than on the original harness.
You will need to get the wiring from ISTA/D then re-wire accordingly. Clearing the errors will require esys to clear the errors.
iAde46
Post by iAde46 » Tue Nov 22, 2016 9:40 pm
Re-wire the front seats?
BRDiagnostics
Post by BRDiagnostics » Wed Nov 23, 2016 6:43 am
iAde46 wrote:Re-wire the front seats?
Lets start from the beginning...
You have swapped your front seats over?
The new seats are heated? & the old ones weren't?
You have two choices - swap the wiring over from the original seats then clear the errors with esys, or rewire & code your car to accommodate the new seats.
iAde46
Post by iAde46 » Wed Nov 23, 2016 7:47 am
Ah yes, cheers for that. I guess they are heated given the extra wiring. I'll re-wire with the existing harness.
Return to “BR Diagnostics & Retrofits”
