Creaky door
Manufactured from end of 2011
H7ayd
Creaky door
Post by H7ayd » Thu Sep 05, 2013 7:08 pm
Hi All
Anyone got a remedy for creaky doors? I think it's the rubber seals around the doors.
________________
Current: 2013 118D M Sport 5dr
Alpine White, BMWP Grill, Black Mirror Caps.
Previous: 2010 118d M Sport 3dr
Previously: 2005 120D ES 5dr
subjectdave
Re: Creaky door
Post by subjectdave » Thu Sep 05, 2013 7:38 pm
'gummi pflege' seems to be the thing - I plan to order some for myself.
F20 M135i | Sports Auto | Black Sapphire
H7ayd
Re: Creaky door
Post by H7ayd » Thu Sep 05, 2013 8:02 pm
Ordered !! I'll let you know how it goes.
________________
Fraggle
Re: Creaky door
Post by Fraggle » Thu Sep 05, 2013 11:48 pm
In my experience gummi pflege is only a temporary fix, and not a very good one at that and leaves an awful smear on the door shuts. I believe BMW have an official fix for this by applying 3M Teflon tape to the door shut contact points.
Gone: 118i M-Sport Glacier
Gone: M135i AW/Coral
Replaced with: Nowt yet.
H7ayd
Re: Creaky door
Post by H7ayd » Fri Sep 06, 2013 11:23 am
May be I'll drop it into the dealers then and see what they say.
________________
MAW73
Re: Creaky door
Post by MAW73 » Fri Sep 06, 2013 2:22 pm
Mine are not creaking at the moment. However, I have noticed when I top the Cquartz protection up with Reload it makes the rubber door seals creak for a week or so afterwards. This has happened every time I have topped up the Reload. I must spray it on a more carefully next time.
Just wondering OP if your creaks have coincided with detailing the car?
H7ayd
Re: Creaky door
Post by H7ayd » Sat Sep 07, 2013 12:44 pm
I think it is related. Yesterday when it was raining and the seals were wet they didn't creak.
________________
118ddk
Creaky door
Post by 118ddk » Sat Sep 07, 2013 2:12 pm
Guys. The problem is the Tiny space between the two felts at the top.
I apply gummipflege with a q tip, so far it has lasted 6 months.
Put some lube in there
/ *L*
118D @ 183hp
/ L
H7ayd
Re: Creaky door
Post by H7ayd » Sun Sep 08, 2013 11:26 am
Is this around the top of the door ?
________________
118ddk
Re: Creaky door
Post by 118ddk » Sun Sep 08, 2013 10:56 pm
H7ayd wrote:Is this around the top of the door ?
Yeah.
/ *L*
118D @ 183hp
/ L
Arrow29
Re: Creaky door
Post by Arrow29 » Sat Mar 15, 2014 4:13 am
So is gummi pflege still the go for this? Mine has started to creak and squeak as well, quite annoying! Tempted to take it to the dealer but would rather a quick fix myself! It's due for its 12 month check in July so I guess if it's still going on I'll ask them about it then.
I've heard some use Autoglym rubber and vinyl care but I've read this contains silicone which is a no no apparently?
EB m135i AT, oyster interior. JB4 and BCS DP on their way
trixie
Re: Creaky door
Post by trixie » Sat Mar 15, 2014 8:57 am
My car started this up after I used some quick detailer (Chemical Guys) between waxes. I then used Gummi-pfledge but this only made mine worse - to be certain I re-used it on one side of the car only and sure enough the creaking was incessant.
I then cleaned all the rubbers down with warm water and car wash, dried with a microfibre towel, repeated this thrice and, while a lot better, it persisted. I then used Dri-lube on the felts (there is conjecture as to whether is will damage rubber seals long-term) and it stopped immediately. I had to repeat the application a couple of times a week apart but it's been nice and quiet for a good month now.
John
Current '05 Renaultsport Clio 182 - '10 BMW E91 320d - Koni Sports
Floating '17 M2 Pure - LBB
118ddk
Re: Creaky door
Post by 118ddk » Sat Mar 15, 2014 9:02 am
trixie wrote:My car started this up after I used some quick detailer (Chemical Guys) between waxes. I then used Gummi-pfledge but this only made mine worse - to be certain I re-used it on one side of the car only and sure enough the creaking was incessant.
Gummipflege last a season here.. no cracks over the summer... must be Applied were the to felt pieces meet.
118D @ 183hp
/ L
foggy
Re: Creaky door
Post by foggy » Tue Mar 18, 2014 4:18 pm
Yep this is the same as mine sounds like creaky doors but if you drop all the windows a couple of mm it stops.
I have some trim stuff on the felts as above but it only last about 10-14 days and then I have to repeat.
markus
Re: Creaky door
Post by markus » Sun May 04, 2014 10:42 pm
So just to be clear, you apply the gummi pflege where the red line on the picture is and not where the blue lines are?
