Hello
Just want to tell you guys how much power you can get out of a 2006mod 118d.
This is my 118d. Its a 2006 mod M-Sport car whit 122hp/280nm from factory.
As you all know this car is realy boring to drive whit stock engine software.
So what have been done:
New custom 120d turbo
New and bigger injectors
Total remove ERG.(see picture)
Remove DPF.
E90 330i breaks. Front 330mm disc and 300mm disc rear.
ERG removed:
Here is some numbers:
Its putting out 250hk@3850rpm and 530Nm @ 2300rpm.This is the same hp that the BMW Motorsport 1998 320d that won the 24h race at Nürburging but my car has higher torque. I got 80% of max power from 2400rpm until 4400rpm. The car is realy fun to drive now.
There is not to much smoke from the exhaust now thtas why only 250hp. I belive 260hp is within reach if I alow more smoke but I dont like to much smoke.
Flywheel and clutch is stock 118d.
And here is a movie. 0-210kmh.
Remove DPF.
ERG removed:
