Bmw 135i Yas Marin blue
ajl00
Re: Bmw 135i Yas Marin blue
Post by ajl00 » Tue Nov 21, 2017 9:06 am
Try again that link above is not the correct item
https://www.ebay.co.uk/i/253133667032
ajl00
Post by ajl00 » Tue Nov 21, 2017 9:08 am
I had to flip the mounting housing over cut the brackets off and make and weld some new ones onto the housing .
ajl00
Post by ajl00 » Tue Nov 21, 2017 9:10 am
Personally I would start with the single cooler depending on usage of the car I should think that it will be up to the job . I went for the twin setup as I wanted to make it future proof . For any further performances upgrades
ajl00
Post by ajl00 » Tue Nov 21, 2017 9:18 am
I had to take a slight nip out off the bottom edge of the bumper return edge to clear the cooler housing, also I had to trim the wheel arch liner for clearance and air flow .
I’m considering m1 bumper and wing conversion so will give them a final tweek if I get round to it .
ajmanby
Post by ajmanby » Tue Nov 21, 2017 10:19 am
Perfect, thanks for that! :D
2011 135i Bluewater with Coral red leather.. DCT - Pro Alloy IC - BMWP exhaust - Birds B1 suspension - M3 LCA - M3 ARB - Stage 1 camber plates - M3 Performance steering wheel - Alufelgen CS7 - Whiteline subframe inserts
Richie pikka
Post by Richie pikka » Sun Jan 07, 2018 7:37 pm
Amazing to see a 135i in yas Marin blue such a lovely colour and suits it...stunning!!
ajl00
Post by ajl00 » Wed May 02, 2018 7:19 am
Just a quick update with the car , just returned from a trip to Europe with some friends car ran faultlessly.
Took in a few laps of the Nurburgring.
Before we left I fitted a new set of Carbotech xp 8 pads , thanks to ian.
I’m fancying a change so vehicle will be going up for sale in the next coming weeks , watch this space . Anthony
ajl00
Post by ajl00 » Wed May 02, 2018 7:25 am
Also fitted a new set of wheels and tyres
1m replicas in gunmetal with r888r toyos
8x18 front 235/40/18
9x18 rears 255 35 /18
THETYRANT
Post by THETYRANT » Wed May 02, 2018 9:08 am
:) looking good fella :)
markhurley
Post by markhurley » Wed May 02, 2018 5:06 pm
Let me know if you fancy parting with The ohlins :D
ajl00
Post by ajl00 » Wed May 02, 2018 5:13 pm
THETYRANT wrote::) looking good fella :)
Cheers mate wheels fill the arches a bit better
ajl00
Post by ajl00 » Wed May 02, 2018 5:17 pm
Hi mark
I was going to see if someone wants to buy the car with all the mods done as it suits the car the way it drives at the minute . Although I do still have the standard suspension to fit back on .
I’ll let you know when I get around to doing an advert .
Rufty
Post by Rufty » Wed May 02, 2018 6:27 pm
Could you pm me with full spec list and the price you're after. This looks pretty much perfect in my opinion.
Sent from my FRD-L09 using Tapatalk
ajl00
Post by ajl00 » Wed May 02, 2018 8:49 pm
Rufty wrote:Could you pm me with full spec list and the price you're after. This looks pretty much perfect in my opinion.
Hi I will try to cover everything then you have the full picture I bought the car back in may 2017 after speaking to ian(tyrant carbotech) I know him from the Mlr forum as I know he has had a few 1 series. So the car is
Bmw 2011 135i e82 coupe 24,000 genuine miles ,7 speed dct transmission. 3 owners
Car was originally Le Mans blue and was professionally painted yard marine blue as this colour is only available on m3 /m4 cars it has been painted inside the door closers and looks factory. Sunroof and air con Bluetooth aux cord connection etc.
Modifications above standard.
Front mounted intercooler and hard pipes
Burger motorsport cold air intake
Wagner tuning decat pipe ( original cat)
Alloy charge pipe (supplied ml performance)
M3 rear subframe bushes (all 4 )
M3 LCA
M3 upper front arm bushes
Wave trac rear lsd fitted by Jc racing with custom lower ratio crown wheel and pinion
(Makes car faster to accelerate as dct ratio is very long )
Tyrant front top mount camber plates
Ohlins road and track with custom spring rates , corner weight setup and ride height by Mick Gardner racing.
Genuine Bmw m cross drilled and grooved discs all round
Carbotech xp10 front pads / pagid rear
Motul 600 brake fluid
Hel performance braided brake lines
Genuine Bmw m carbon rear spoiler
Stud and nut wheel nut conversion
Bimec wheel spacers
Twin oil cooler front setup , car runs 95-100 degrees now . These cars suffer from oil over heat . 135/335 turbo are renowned for overheating the oil temps then going into limp mode . It has a billet take of plate and an in-line mocsl oil thermostat all on -10 braided lines and alloy fittings.
The car came with a jb4 fitted which I had removed and a custom re map done by Dervtec tuning in manchester. They came recommended and a doing loads of 135/140 cars .they did a nice and safe tune to suit the mods the car made 375bhp (I have a dyno readout somewhere . They said the car would make around 500 with a hybrid turbo fitted without the need for any extra mods they said the original fuel had loads of headroom.
I have the original wheels in gunmetal grey metallic with Toyo r888r
7.5” Front 225 40 18
8.5”Rear 255 35 18
And a brand new set of 1m replica wheels gunmetal with toyo r888r (3weeks old )
8” front 235/40/18
9” rear 255/35/18
I also have all the standard suspension and cat pipe off the car . All the above mods have been on the car for less than 2000 miles , the car has been serviced with fully synthetic motul oil and a new mot .
Prior to me buying the car . The first owner was disabled and the car had hand controls fitted .the car was damaged on the near side front corner and is registered on v car as a category d . Which is light damage . The car was purchased by a Bodyshop owner who bought and repaired the car for himself ( I spoke to him prior to purchase ) and did the colour Chang to taste marine blue . He then sold the car to the guy I bought it from who only used it at the weekends then had to sell due to needing a family car .
Since I have had the car I have spent over £9600 on modifying the car for fast road spec . The car is very usable and easy to drive and will keep up with e92 m3’s with ease I have 3 friends with those cars . But also makes for a car you can use everyday it also returns decent mpg due to the 7 speed box .
I would be looking for around £17500 with the cars as it is the standard parts could go with it within the price for a hassle free sale which would return some money .
I have had people contacting me regarding selling the diff and suspension . But in my opinion the car is just right with the spec it has and the low mileage.
I think that covers about everything thanks Anthony.
I am going on holiday next Wednesday for 3 weeks if you need any more info just let me know .
Rufty
Post by Rufty » Thu May 03, 2018 1:10 pm
Best of luck with sale, a bit out of my price range personally. Though with the quality of the mods carried out, I don't doubt you'll get full asking price. Hope you have a brilliant holiday.
