i have scoured the web looking for a guide for the e87 to enable the aux in on the bmw business cd radio .
information is a bit scattered so here is my take on it.
the vehicle i was working on was an 05 120d and had an oem aux input.
after i had fixed the initial issue with broken steering lock motor and then ews cas dme mismatch, it came back with aux in mode not showing on the radio.
apparently the aux in function requires some sort of resistor between inputs on the aux cable AND a flag in the radio firmware to enable aux input in the radio menu.
in my case the flag in firmware seemed to have reset to aux off
i did reflash the cas module but this seems a common problem after battery disconnection or flat battery
steps i followed were:
install standard bmw tools inc ncs expert
then loosely following the guide here
deviations from this in CAPS
1. in ncs expert click file then load profile.
select expert mode click ok
2. select f1
then f3
I CHOSE E89 AS I HAD NO E87 OPTION click ok
3.choose cas click ok
select f2
CHOOSE E89 click ok
next box click ok
enter +naux in the attribute box and then press add
then click ok
4. click f6
click f4 choose cas then click ok
click f2 choose fa_write click ok
click f3
exit ncs expert
5.restart ncs expert
SELECT EXPERT MODE click ok
click f1
click f3 SELECT E89 click ok
select cas click ok
click f6
click f4 SELECT RAD1 click ok
click ok on the popup window
click f2 select CODIERDATEN_LESEN click ok
click f4
close the popup window
minimise ncs expert window
go to your windows desktop
6. navigate to your ncs expert directory usually c:ncsexper
click on the folder and then the work folder contained in it
find FSW_PSW.TRC than open it with notepad
find the line with:
aux
no_aux
delete the 'no_' part then save as (choose type all files) FSW_PSW.MAN
7. go back to ncs expert
click f2 choose SG_CODIEREN click ok
click f3
when that job has finished exit ncs expert , unplug your cable , turn off the ignition.
turn ignition on and for me at least aux function is re-enabled
hope this helps : follow the video just choose the different options i highlighted and you should be ok ;-)
