My130's Journey
16K views 89 replies 15 participants last post by  RoyBoy777
Hi Guys.
I've had the car since Dec15. Not done much to it just tinkered with it gently along the way while deciding what to do. Still not sure how far I plan on going as at this time it's still my daily ! Time will tell !
I will try keep it update with its current spec and work done, where and who I got the stuff from and where I can will post the prices part no etc
You will find the spec etc in the second posting of this thread .
#2 ·
Car : 2006 Bmw E87 130i M-Sport
Car Spec:
Manual
I-drive
Cruise control
Heated Seats ( Leather)
Work done so far :
Engine flush in Dec 15
Full service
Washer bottle cleaned what a pain that was !( Now use Bluecol )
Mods :
Exterior:
Smoked side repeaters, Philips silvervision bulbs, Philips silver indicator bulbs
Both washer jets replaced & twin on the back
Stubby Aerial
Rear lights and windows tinted
Front Carbon Fibre splitters (SK performance)
Aluminium Number plates
Interior:
CiC controller (E-Bay) Coding done by Wibbles
Storm V2 gear knob (E-Bay)
Now ZHP Style gear knob (E-bay)
Flat Bottomed Steering wheel (E-Bay, Germany 170 Euro's)
Engine:
Rev black Silicone intake hose
BmwP Style grilles (E-Bay)
Air scoops
Gearbox/Diff
Short Shifter (Cotswold Bmw)
CDV Value (Cotswold Bmw)
Oils Red line MTL + Redline D4 Should be better on the cold mornings (Opie Oils)
Diff Red line 75w90 (Opie Oils)
Poly Mounts 80a,same as e46 M3 I believe (Hack Eng)
Suspension/ Chassis :
Birds B1 suspension ( Thanks Rustle)
Now Koni Yellow sport dampers
BmwP springs ( Thanks Tyrant & Mark)
BmwP bumpstops front & rear.( Cotswold Bmw)
M3 arms, Meyle trackrod ends etc Autodoc)
Whiteline inserts
M3 E92 front ARB. ( Breakers)
Meyle Hd drop links
Trw M3 arms (rear) (Autodoc)
E81 under chassis/body brace
Brakes
Front : Oem replaced (Dec15)
Now M135i Brakes with Oem pads.
Goodridge braided hoses
Rear : M-Tec black edition, yellow stuff pads
update: 135i Rear calipers,
rear disc (B34.21.6.795.755)(Cotswold )
BmwP exhaust (group Buy)
Wheels
Autec 18's Et 45
Hankook V12 225/40 Front , 235/40 rear
#4 ·
Looks a nice motor buddy, love the colour. I may be slightly biased but some polished deep dish wheels would set it off :rollseyes:
#6 ·
Nice mate.
Looks very similar to how mine was. Good to see a LeMans blue with black kidney grills - been thinking of changing them but weirdly like the chrome on the 130i!
#15 ·
marctwoo said:
How did the gearbox mounts work out for you? Make much difference to shift feel and cabin noise/vibration over OEM?
Marc
The gear change is vastly improved ! Although all the work was done at the same time, weighted gear knob probably made the biggest difference there ! The only downside side is the cabin noise has increased but am used to it now so don't notice it as much !
#16 ·
Small update :
Car had her mot, passed no problems!
Had the rear brake disks and pads done ! M-tec disks yellow stuff pads !
Was hoping to get the braided lines done and new fluid at the same time. However fluids arrived no problem, lines didn't arrive in time so was annoyed especially as I had ordered them 6 weeks before mot was due!
#17 ·
Might have to get me a weighted gear knob as well then. I've got the BMW SSK and a fresh CDV waiting to be fitted, still mulling over whether I should get the mounts done as well. I'm leaning towards the M3 OEM ones.
What about the clutch stop? Never come across that before. I was under the assumption it's good practice to fully press the clutch pedal all the way to the floor before doing a gear change (obviously skip that advice when having some fun :D )
#18 ·
Jonwilli has one sounded worth a go cost peanuts! Still to be fitted !
I believe mine are the M3 E46 spec , same as on Jon's car . Haven't driven it in anger much since then !
Where did you order your brake lines from?
I paid just under ÂŁ120 for a full set of Hel braided lines from Helperformance.com with lifetime warranty. Arrived in 3 days.
Car is looking good. How about Led Darklines to modernise the rear? I'm planning on doing that next year. Cotswold quoted ÂŁ336 for the kit including wiring. They'll need coding too.
They Goodridge brake lines, paid about the same I think ! They said that Goodridge had to make them , then 1st set got lost in the post bla bla , can't remember the name of the company will have to find the invoice!
Led Darklines : I'm not sure, I don't mind the rears to much ! Especially since I tinted them red not so in your face bright ! If I'm honest I would rather spend the money elsewhere for now !
Want to get plugs , coils , vanos , water pump and thermostat done in the 1st half of the new year!
More for total peace of mind than anything else!
Then finish the suspension and Lsd ! Would be a great year on the car !
#19 ·
Not much happening with the car at the mo !
Just had my usual early year oil change gone with the 5w40, castrol . Coolant change and spark plugs changed !
Ordered a new rear wiper motor as that packed up this week !
Need to respray the bonnet as has 2 areas where the clear lacquer has come off super annoying! Money I could have spent elsewhere! Frustrating!
#21 ·
Davy130 said:
Enjoyed your write up. When you got your new cdv did you need to alter it or did it come ready. Have a 130i so i have taken on board your upgrades.
Sent from my LG-D802 using Tapatalk
Hi .
Bought a new one and removed the little piece in the middle that restricts the fluid. There is a how to do it somewhere on here !
#23 ·
Just buy one from BMW over here it's so easy to modify takes about 10 seconds ! Don't waste your money on one from the states
#24 ·
Davy130 said:
Good stuff. I read somewhere that u can get one allready altered from America i think. Depends on the cost if that one etc compared to a diy. Thanks for the reply.
Mate. 2 sec job ,don't waste the cash on it from the states.
